  • greentel Friend
    #135477
    Hi guys n girls – Module & Banner issue with box boundaries
    Iv been hunting for an answer to a problem which so far i have come up with no solution. I wonder if i can ask for your help.
    I have created many text banners within the component “banner” and then use the module banners to display these for different pages of the site… the problem im finding is that the box then displays correctly the text i requested but the surround display creates an incomplete border and indents into the module this happens even if i put the module in any other location.
    The site is in maintenance mode however it can be viewed by logging in U: joomlart P: pass
    an example would be http://live24seven.co.uk/index.php?option=com_sobi2&Itemid=97
    note i have tried with and without _text
    I hope i can find an answer many thanks
    Luke
    #279739
    Hi greentel !
    I need account to view your site, now it is offline so i can’t view it.
    jwellman Friend
    #279774
    Hainn,
    I was able to get in with the user name and password he provided above.
This topic contains 3 replies, has 3 voices, and was last updated by  jwellman 15 years, 12 months ago.
