  • Sylvain ipoua Friend
    #128664
    Hi all,
    Can someone help me find the right way to build a single sign for my users?They will log on once and access different services(Forum (phpbb…), shopping (virtumart…), comments …) on my site.
    What modules/plugin needeed to allow this?
    Do jFusion, Community builder… can help?
    Thanks in advance for your help.
    Sylvain
    Omar Ramos JAEC
    #249616
    The Joomla signon will automatically allows users to use Virtuemart, Comments on your site automatically since those are addons for Joomla.
    The only one you’ll have any trouble with is the phpBB integration and JFusion will handle that for you (but it only works one way…if I remember correctly JFusion handles from phpBB to the Joomla database but not the other way around…though that synchronization feature should be coming up in a new version of JFusion).
    Hope that helps!
    Menalto Friend
    #249789
    You can allways take a look HERE for a bridge between joomla and phpbb
This topic contains 3 replies, has 3 voices, and was last updated by  Menalto 16 years, 7 months ago.
