November 29, 2007 at 6:16 pm #124077
Hi! See my site http://www.ischiaservizi.com and the top menu.
In IE i see a bug and in Firefox another bug!!! Please try mouseover topmenu icon with this 2 browser!!! How can i solve this? Please help me, is so urgent!
Menalto FriendMenalto
- May 2007
- 531 times in 361 posts
December 1, 2007 at 11:11 am #233736Site offline, no change to check it…
December 1, 2007 at 2:33 pm #233744NOW is online. I apologize… Please, help me!
Khanh Le ModeratorKhanh Le
- November 2013
- 203 times in 131 posts
December 4, 2007 at 1:28 am #233852The problem is the image http://ischiaservizi.com/images/stories/10-home-big.png is missing. The top menu need a pair of images for each item.
December 4, 2007 at 10:55 am #233878Khan, very very thank about your answer. How can i download the top-menu image (in this twoo extension), i see in the skin of JA demo? I see not in my skin folder!
Another question, please. How can i create a top menu item with this image, when i create a “component” item? I see the image selector in “content” menu item, but not in “component”!
Very very thank…
- November 2013
December 5, 2007 at 3:28 am #233933To create Icon menus, please read the readme document (or userguide document), section 7.
You could get menu icons in source package of this template:
http://www.joomlart.com/downloads/cat/joomlart_club_templates/ja_utahia_and_ja_utahia_ii.htmlDecember 7, 2007 at 9:14 am #234094Yes, i see this. I correct upload images and see the guide; all menu item are correct but not the component item!! I see not correct a Fabrik-Form button, in the menu item panel i cannot image setting!! How can i, in topmenu, a link at fabrik form with images insert?? See http://www.ischiabrochure.com please.
Very thanks!
roderick1 Friendroderick1
- January 2008
February 7, 2008 at 8:46 pm #238533I have a different question,what did you use to get your site (http://www.ischiaservizi.com) to be in english and italian…please i ned to now… thank you!
you can email me at mailroderick@gmail.comSherlock FriendSherlock
- 2478 times in 2162 posts
February 12, 2008 at 2:43 am #238913Hi Archimede,
Your site http://www.ischiabrochure.com is offline….Sherlock FriendSherlock
February 12, 2008 at 2:46 am #238914Hi Roderick1,
You can use JoomFish component to build multi-language as http://www.ischiaservizi.com . You can find it on http://www.extensions.joomla.org.
Good luck. -
This topic contains 10 replies, has 6 voices, and was last updated by Sherlock 16 years, 11 months ago.
