  • christofferl Friend
    #159206
    A.) I am experiencing a big problem with the menu module in this template and I know the problem that is causing it.
    As you can see in the attached images, the top node of my menu is somehow reduced to the 2nd node (?). I see that the problem appears every time I use the menu item as a “Separator” … if I am not using it all looks OK.
    B.) I am also lacking a highlightning in the menu module of the 2nd node (submenu) when active (see image attached).
    Hope you can look at these issues and let me know what to do. I am willing to test any ideas!
    1. ja_14a
    2. ja_14b
    3. ja_14c
    aman204 Friend
    #373645
    Can you provide a link to your site
    christofferl Friend
    #373646
    Hi, I have just sent you a privat message with all the login details including how to login at the backend.
    Hope you can find a solution 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  christofferl 13 years, 11 months ago.
