October 20, 2010 at 5:45 pm #155474
I installed the Quick Start JA Droid with sample data.
I’m able to login into the administrator side of joomla but when I try to show the front end a blank page appears. I get the same changing the template, too.
Could somebody please give me and help.
Thank you.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
October 20, 2010 at 6:21 pm #359731If you change template and get the same then something must have gone wrong with the install. It could be that some files did not upload correctly. Always use a good ftp program and not web based ftp. I recommend the free Filezilla ftp app – http://filezilla-project.org/
Re upload al the files then begin the install again.
October 20, 2010 at 8:46 pm #359745<em>@phill luckhurst 199451 wrote:</em><blockquote>If you change template and get the same then something must have gone wrong with the install. It could be that some files did not upload correctly. Always use a good ftp program and not web based ftp. I recommend the free Filezilla ftp app – http://filezilla-project.org/
Re upload al the files then begin the install again.</blockquote>
I’m working in localhost. The files are copied directly in the folder.
?Phill ModeratorPhill
- February 2014
October 20, 2010 at 8:49 pm #359747Then it must be a local setup problem. Are you using Xampp or Wamp or a linux box?
- February 2014
October 20, 2010 at 9:09 pm #359748Just made an install on my machine using PHP5.3 under Wamp and all is fine. Not really sure what else I can do to help
October 20, 2010 at 9:23 pm #359749I’m using Mac OS X with MAMP, I tried both MAMP 1.7.2 and MAMP 1.9.3.
In JoomlArt Extensions Manager/Repository Manager I found some Errors in Components, Modules, Plugins and templates.
i.e.
‘/Applications/MAMP/htdocs/primula.it.2010/jaextmanager_data//component’ in Components
‘/Applications/MAMP/htdocs/primula.it.2010/jaextmanager_data//module’ in Modules
etc…How can I change these paths?
The problem may be in the double slashes, the error I get is “Path is not a folder or this folder was deleted.” -
This topic contains 6 replies, has 2 voices, and was last updated by robertolaglia 14 years, 3 months ago.
