  • gonzela2006 Friend
    #156961
    Hello Joomlart Team and all members,
    First of all thanks for that great T3 FrameWork 2.0
    I have a complex question:
    How can I give the block-inner divs the same height of left block??
    Here is what I wrote on my layout
    <blocks name="middle" colwidth="33" fixheight="1">
    <block name="right1" block-inner="3">left</block>
    <block name="right2" block-inner="3">right</block>
    </blocks>
    let say our generated html code will be
    <div id=”ja-right1″ style=”width: 50%; min-height: 1125px;” class=”ja-col ja-right1 column”>
    <div class=”block-inner1″>
    <div class=”block-inner2″>
    <div class=”block-inner3 clearfix”>
    <div id=”Mod48″ class=”ja-moduletable moduletable clearfix”>
    <h3><span>Lorem ipsum</span></h3>
    <div class=”ja-box-ct clearfix”>
    <p>
    Lorem ipsum dolor sit amet, consectetur adipiscing elit. Pellentesque et augue vitae nisl viverra laoreet. Donec ut ligula mauris, eu fringilla est. Aliquam luctus, elit eu pellentesque blandit, sapien massa ullamcorper dui, vitae aliquet arcu nunc non odio. Donec porta lacus non est commodo in volutpat massa sagittis.
    </p>
    </div>
    </div>
    </div>
    </div>
    </div>
    </div>
    I want to give (block-inner1, block-inner2 and block-inner3) divs the same height of id “ja-right1” which is “min-height: 1125px;”
    #365107
    Dear gonzela2006,
    Can you let me know why you need to make the same height for those element ? the height of id “ja-right1” as well other columns they are set in javascript function of the core framework.
    It is quite complicated and you can try as following to get it
    Go to the file of plugins/system/jat3/base-themes/default/js/core.js file,looking for the below ja codes
    [PHP] els.each(function(el, i){
    if (!el) return;
    if (height-el.getStyle(‘padding-top’).toInt()-el.getStyle(‘padding-bottom’).toInt() > 0) el.setStyle(‘min-height’, height-el.getStyle(‘padding-top’).toInt()-el.getStyle(‘padding-bottom’).toInt());
    });[/PHP] You can change it to
    if (!el) return;
    el.getElements(‘div’).each(function(item,i){
    if(item.getProperty(‘class’).contains(‘block-inner’)) { item.setStyle(‘min-height’, height-el.getStyle(‘padding-top’).toInt()-el.getStyle(‘padding-bottom’).toInt()); }
    }); [/PHP] I do hope it would help !
    gonzela2006 Friend
    #365288
    <em>@dathq 206390 wrote:</em><blockquote>
    if (!el) return;
    if (!el) return;
    }); [/PHP] I do hope it would help !</blockquote>
    Thank you very MUCHHHH
    it works great
    <em>@dathq 206390 wrote:</em><blockquote>Dear gonzela2006,
    </blockquote>
    I have a design which have more than one backgroud (three background). these backgrounds applied for “ja-right1”, “ja-right2”, “ja-left1” and “ja-left2” so the solution is to wrap thoses divs so they can take the same height I tried “block-inner” property but it wraped “ja-right1” content not the “ja-right1” div
    if you have a better solution rather than the above, it will be great??
    I have another problem I want to wrap the “.ja-content-main” with 3 divs to give it the 3 backgrounds how can I do it? I don’t know what to write on the XML layout
    Thanks for your time dathq
    T3 is the best
    gonzela2006 Friend
    #365309
    <blockquote>I have another problem I want to wrap the “.ja-content-main” with 3 divs to give it the 3 backgrounds how can I do it? I don’t know what to write on the XML layout
    </blockquote>
    any help please
    #365506
    Dear gonzela2006,
    If you want to wrap the “.ja-content-main” with 3 divs you can try as following
    1 ) Copy the file of pluginssystemjat3base-themesdefaultpagedefault.php into the folder
    templatesyour_templatepage (you need to create the page folder if it does not exists)
    2) Open the copied file & search for the Codes below
    [PHP] <?php if (!$this->getParam (‘hide_content_block’, 0)): ?>
    <div id=”ja-content-main” class=”ja-content-main clearfix”>
    <?php echo $this->showBlock (‘content’) ?>
    </div>
    <?php endif ?>[/PHP] Here you can wrap the .ja-content-main by the divs as you want
    hjames Friend
    #369155
    This thread helped me to remove the constant height in my template which was also being controled by core.js.
    Thank you!
    James
    Phill Moderator
    #369156
    It would be really good to see your completed work. Please come back and show it off when done.
    hjames Friend
    #369157
    I can deffinitely do that!
This topic contains 8 replies, has 4 voices, and was last updated by  hjames 13 years, 12 months ago.
