December 18, 2013 at 3:38 pm #193072
I have an issue in a category blog layout configured in the menu item and in the category properties with 1 leading articles, 8 intro articles, 2 columns, and 0 links.
Instead of showing 1 leading articles, I have 2, even thought the settings I have 1.
How can I fix this?
This happens in all my blog layout. For example:
http://www.auroraboreal.net/j3/index.php/artehttp://www.auroraboreal.net/j3 is a joomla 3 migration from a j1.5 installation. In the original site I did not have that problem…
http://auroraboreal.net/index.php?option=com_content&view=section&layout=blog&id=16&Itemid=159It’s a problem related to the template: if I switch to another template, the problem disappears:
http://www.auroraboreal.net/j3/index.php/cultural?template=protostarphong nam Friendphong nam
- May 2015
- 974 times in 888 posts
December 19, 2013 at 2:29 pm #515964Hi,
In this case, we would like to suggest you to take a backup of site and follow these steps:
– Update the latest version of T3v2 2.6.9.
– Backup and overwrite the templates/ja_teline_iii/html/com_content/category/ folder with my attached file.Note: Make sure your website is still running on Joomla 3.1.5 version since there is no update of this JA Teline III template on Joomla 3.2.x at this time. Remember to clear JAT3 cache after updating changes.
If the suggestion is not effective on your website, you can send me PM with the credentials of the site. I will help you to check out it and back to give you a suitable solution then.
1 user says Thank You to phong nam for this useful post
December 20, 2013 at 11:25 am #516073Thanks Leo,
unfortunately, I already have Joomla 3.2.1
Is there anything I can do in this case? How do I downgrade?!I hope you can still manage to help me out…
- May 2015
December 22, 2013 at 4:31 pm #516171Hi merzbau,
It will be great when you take a backup of J3.1.5 site before upgrading. So, you can roll back the previous update by extracting this backup. If not, I am afraid that you will have to do many steps to get the site work well on Joomla 3.1.5 again.
This topic contains 4 replies, has 2 voices, and was last updated by phong nam 11 years ago.
