  • sobe Friend
    #201998
    There seems to be a problem with the blog layout when 1 Leading Article is selected followed by a few Intro Articles displayed with two columns. The first article works fine, but the 2nd article seems completely misaligned (somewhat similar to the 1st article, yet off to the side), and then the other articles appear in two columns properly.
    I just re-installed the quickstart template (J version 3.3) and chose to modify the “J! Blog” menu to have 1 Leading Article, 4 Intro Articles, and 2 Columns and the problem is easily replicable.
    How do I get the page to have simply 1 leading article, and then the rest in two columns?
    Hi sobe,
    You can try with my tweak here:
    – Open file: templatesja_fixelhtmlcom_contentcategoryblog.php
    – At approx line 80, you will see this snippet of code:
    <?php
    $key = ($key - $leadingcount) + 1;
    $rowcount = (((int) $key - 1) % (int) $this->columns) + 1;
    $row = $counter / $this->columns;
    if ($rowcount == 1) : ?>
    <div class="items-row cols-<?php echo (int) $this->columns;?> <?php echo 'row-'.$row; ?> row-fluid">
    Replace it with:
    <?php
    if ($rowcount != 1) : ?>
    Hope it helps.
    sobe Friend
    #552737
    Hi Saguaros,
    You’re tweak did resolve the second article issue, but it also created another problem. Now, for some reason the two column layout is skipping the third article and leaving an empty space where that article should be.
    You can PM me admin and ftp credentials of your site, I will take a look.
    sobe Friend
    #553136
    Hi Saguaros,
    Any progress in helping to resolve the issue?
    Thanks again for your help.
    Hi sobe,
    I replace this:
    <?php if (!empty($this->intro_items)) : ?>
    <?php foreach ($this->intro_items as $key => &$item) : ?>
    <?php
    With:
    <?php $rowcount = ((int) $counter % (int) $this->columns) + 1; ?>
    <?php if ($rowcount == 1) : ?>
    <?php $row = $counter / $this->columns; ?>
    I also back up the old file so that you can see the difference.
    Have a nice day
This topic contains 6 replies, has 2 voices, and was last updated by  Saguaros 10 years, 2 months ago.
