  • suli3 Friend
    #140382
    Hi all
    Ho i can the combine
    The header and footer of the blue style but with the body of the default theme.
    Thanks for help
    John Wesley Brett Moderator
    #301857
    Before you do anything…back up all of the files mentioned below…so you can return them if you are not satisfied with the look. Good luck.
    In the template/images/blue/ folder copy the following files into the default folder overwriting the files with the same names:
    Then change template.css (line 19) to read:
    body#bd {
    background:#042733 url(../images/body-bg.jpg) repeat-x scroll center top;
    color:#20576A;
    And make template.css (line 835) read:
    #ja-header {
    background:transparent url(../images/header-bg.gif) repeat-x scroll left bottom;
    height:auto !important;
    min-height:160px;
    And to change the footer….
    In template.css (line 1172)
    replace the #ja-footer code with the following:
    #ja-footer {
    background:#011821 none repeat scroll 0 0;
    border-top:1px solid #011F2A;
    color:#072F3B;
    There may be additional tweaking necessary, but this should get you started.
    John.
    Remember to Click “Thank You” when you find a post useful.
This topic contains 2 replies, has 2 voices, and was last updated by  John Wesley Brett 15 years, 8 months ago.
