  • ooweboo Friend
    #148157
    I would like to change the color of the body background that is currently black to #FADFB6. That is the background of the section that contains the text “Camelia Guest House is located/situated in the tranquil up-market suburb…..”. I want to change that background on all the pages. And then the text color (on this background) must be black. Your help will be appreciated.
    Thank you in advance!
    Hello guy
    Please open the file: /templates/ja_cooper/css/template.css and try to find codes at line 610
    #ja-current-content {
    background: #181818;
    margin-bottom: 10px;
    padding: 10px 15px 15px;
    Replace:
    background:#FADFB6 none repeat scroll 0 0;
    color:#404040;
    margin-bottom:10px;
    padding:10px 15px 15px;
    – And try to find codes at line
    h2.contentheading, .contentheading {
    margin: 0;
    padding: 0;
    font-size: 200%;
    and replace:
    margin: 0;
    padding: 0;
    font-size: 200%;
    color:#404040
    Good luck
    ooweboo Friend
    #331329
    Thank you very much – your solution works perfectly!!!!
This topic contains 3 replies, has 2 voices, and was last updated by  ooweboo 14 years, 10 months ago.
