osignite Friend
osignite
- February 2011
March 30, 2011 at 6:27 pm #162159I am using te JA Community Plus template. The theme is the ‘default’ I have changed the background to display a background image and color. It shows up fine in Firefox and Chrome. But on IE 8 (which I have installed) it is showing a blue color. I have done a search and replace for all of the files within the template and can’t locate the blue color.
I have no clue why this is happening.
My demo is http://www.mcdmediausa.com/ocwarehouses/
You can see in Firefox the color should be the green gradient color.
Any help would be appreciated.
Phill ModeratorPhill
- February 2014
- 2206 times in 1818 posts
March 30, 2011 at 6:48 pm #384135You may need to clear your temporary internet files/cache on IE8 becasue I am seeing the green gradient as you have set.
osignite Friendosignite
- February 2011
March 30, 2011 at 6:56 pm #384140<em>@phill luckhurst 231290 wrote:</em><blockquote>You may need to clear your temporary internet files/cache on IE8 becasue I am seeing the green gradient as you have set.</blockquote>
Sorry you are right. Please check the ‘available’ tab and ‘contact’ tab those still are that blue color.
chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
March 30, 2011 at 7:01 pm #384141<em>@osignite 231285 wrote:</em><blockquote>I am using te JA Community Plus template. The theme is the ‘default’ I have changed the background to display a background image and color. It shows up fine in Firefox and Chrome. But on IE 8 (which I have installed) it is showing a blue color. I have done a search and replace for all of the files within the template and can’t locate the blue color.
Any help would be appreciated.</blockquote>
I see the same gradient Background image in Both IE 7, IE 8. If you want I can provide you the screenshot
Please clear cache , cookies and check the Site again
1 user says Thank You to chavan for this useful post
- February 2011
March 30, 2011 at 7:06 pm #384142<em>@Chavan 231296 wrote:</em><blockquote>I see the same gradient Background image in Both IE 7, IE 8. If you want I can provide you the screenshot
Please clear cache , cookies and check the Site again</blockquote>
The issue was with the T3 cache. I cleared the T3 cache and its all good now. I appreciate the help from everyone!
1 user says Thank You to osignite for this useful post
This topic contains 5 replies, has 3 voices, and was last updated by osignite 13 years, 9 months ago.
