  • mpinchuk Friend
    #176028
    Hello!
    How can I change body color of JA Anion? I want it wite.
    I changed body#bd { background: url(../images/grad01.gif) left top repeat-x; background-color: #fff; color: #353535; } in
    templatesja_anionthemeslight-greencsscolor.css
    But it did help. Only partially.
    khoand Friend
    #448108
    <em>@mpinchuk 313380 wrote:</em><blockquote>Hello!
    But it did help. Only partially.</blockquote>
    – You change this code from /templates/ja_anion/core/themes/light-green/css/color.css
    body#bd {
    background-color: #44532F;
    color: #353535;
    – You delete all of files of /cache and /t3-assets directory.
    mpinchuk Friend
    #448115
    I made that you adviced
    But the top of body didn’t change
    The top part of body is steel green
    khoand Friend
    #448119
    <em>@mpinchuk 313395 wrote:</em><blockquote>I made that you adviced
    The top part of body is steel green</blockquote>
    You go to Template manager,choose JA Anion template, then change CSS Optomize fieds to NO, so I can check how and where to customize for you.
    Could you give me a link to your page as you said?
    mpinchuk Friend
    #448195
    I can’t give you the link because it is locally now.
    This is what I have now.
    1. Untitled
    khoand Friend
    #448196
    <em>@mpinchuk 313501 wrote:</em><blockquote>I can’t give you the link because it is locally now.
    </blockquote>
    I can’t help you if I don’t see your website directly. So when you publish your website and your issue is available, you inform me, I will help you.
    mpinchuk Friend
    #448414
    I published my website.
    Can you help me with body and themes color?
    khoand Friend
    #448904
    What is your link?
    mpinchuk Friend
    #448907
    khoand Friend
    #448924
    You just remove the bold text from code
    body#bd {
    background-color: white;
    color: #353535;
    mpinchuk Friend
    #448970
    But what should I change next to change body color of template?
    khoand Friend
    #449096
    <em>@mpinchuk 314584 wrote:</em><blockquote>But what should I change next to change body color of template?</blockquote>
    I don’t understand what you mean clearly. Could you explain more?
    mpinchuk Friend
    #449098
    I want body to be white, not green.
    Now what I received is bottom white and top is green.
    khoand Friend
    #449103
    <em>@mpinchuk 314727 wrote:</em><blockquote>I want body to be white, not green.
    Now what I received is bottom white and top is green.</blockquote>
    You replace the code from http://hot-kitchen.com/templates/ja_anion/themes/light-green/css/color.css, please
    body#bd {
    color: #353535;
    with
    body#bd {
    color: #353535;
    mpinchuk Friend
    #449127
    Thanks. It is work.
This topic contains 15 replies, has 2 voices, and was last updated by  mpinchuk 12 years, 8 months ago.
