  • geleugim Friend
    #132285
    If you have multiple tabs configured and they are uneven in height then you will see the problem.
    Problem:
    If you expand the body then, while the body is expanded, click on a tab, if that tab needs to increase in height it will do so but it will not push the footer area down.
    Workaround:
    A workaround of this is to make sure that all your Tabs are equal in height.
    If anyone comes up with a solution I would love to know it. This scenerio happens on my site and on the Demo site that Joomlart provides.
    my site:http://ks1.kamiscraps.com
    Menalto Friend
    #272533
    Did you sort this out yet? If you did please mark this as solved, if not justreply here and we will try to help you out as we can.
    geleugim Friend
    #272751
    I posted a workaround, but the problem is still there. The problem occurs whether you use the quickstart or the template package and it also happens on the demo site. If a fix is posted, I will apply it; but I am not willing to cry about it if it’s not fixed.
This topic contains 3 replies, has 2 voices, and was last updated by  geleugim 16 years, 2 months ago.
