giving the same reply I gave you to your other ticket.
The link you have mentioned http://www.joomlart.com/static/guides/layout/?ja_nickel is for checking the module positions guide so you are seeing all the positions available in your template. But BODY is not a module position, it is your main content area, where your articles / component outputs such as contact form etc are displayed. This content is controlled by the menu items you create, like Home, Contact Us etc.
To know more about setting up your template, you can refer to following links
http://www.joomlart.com/forums/topic/ja-nickel-template-installation-and-configuration/
http://www.joomlart.com/forums/topic/ja-nickel-userguide/
