  • timjburrows Friend
    #119571
    I have set up the Antares template so that there is a user module in left position, which is configured to only be published on the home page. What I am finding is that it looks fine on the home page, but when I go to one of the submenus, the body module is not left aligned.
    Can anyone tell me how to get the main body to appear left aligned in this situation? I have completely unpublished the user module, and the body is left aligned on the home page, but keeps moving to the right whenever I go to a sub menu.
    Cheers.
    bernhar Friend
    #217428
    Can you give the URL (maybe via PM). What do you mean by body module? Could be a module that is responsible for this behaviour.
    bernhar Friend
    #217433
    Aah, now I see the problem. This must be connected to your modufication of the template. How did you delete the hard coded main menu?
    timjburrows Friend
    #217434
    Well that’s a good question. I think I followed the direction of one of the people that posted on this forum, to get the header to 100% width. I wanted a horizontal menu with the full page rotating image below it… let me see if I can find the post…
    timjburrows Friend
    #217435
    Pretty sure I followed the directions in this post here:
    http://www.joomlart.com/forums/topic/how-to-remove-main-menu-set-banner-100/
    timjburrows Friend
    #217488
    Why is this classed as solved now? Is it because templates are not supported once they have been modified.
    bernhar Friend
    #217489
    Must be a mistake. As far as I know templates are supported pretty well. Unfortunately I had no time to look at the problem more closely since yesterday.
This topic contains 7 replies, has 2 voices, and was last updated by  bernhar 17 years, 8 months ago.
