  • mayke Friend
    #136596
    How to assign modules on BODY position?
    I can’t find the ‘body’ position in the module manager?
    Please advice.
    Thank you.
    sfpkent Friend
    #284323
    You have to type this in your articles:
    {loadposition yourposition}
    I believe there is a component or module allow you to publish module directly into your body, but you have to search at http://extensions.joomla.org.
    Good luck!
    mayke Friend
    #284683
    Thank you sfpkent,
    I’ve been thinking to add new position above the body.
    Thanks.
    scotty Friend
    #284685
    sfpkent;102549Hi,
    Good luck!
    It’s actually preinstalled in Joomla. I wrote a brief tutorial a while back here…
    http://www.joomlart.com/forums/topic/how-to-place-a-module-inside-an-article-or-main-content-area/
    This is for loading a module anywhere inside an article. I think Mayke is looking for something a little different where he want’s a total new position above the content area?
    scotty Friend
    #284686
    mayke;103374Thank you sfpkent,
    Thanks.
    By “body” do you mean main content area or the whole “body” of the page? If you can post a scrennie I’ll do it for you.
This topic contains 5 replies, has 3 voices, and was last updated by  scotty 15 years, 10 months ago.
