  • lucine Friend
    #148178
    Sorry to make a second post with the same problem,
    but I think that the lack of the “body” position is very inconvenient,
    for a good customization,
    Could you find a way to fit my needs ?
    Thanks by advance
    lamvt Friend
    #330952
    DOnt undertstand, what do you mean??
    what do you want to say??
    lucine Friend
    #330986
    Hi lamvt,
    On the overview of Kyanite features there is a “body” position for “content” and “modules”.
    See attachment …
    But when I want to put a module in this position (“Body”), there isn’t the “Body” possibility …
    See attachment …
    I had the same problem with a quickstart installation …
    And when I try ?tp=1, I have only breadcrumbs position at this place …
    I hope that you understand and that you can give me a solution to my problem,
    Best regards
    1. CS-001
    2. body-position-missing
    oudemans Friend
    #331019
    For me the same,
    I can not find the body option to, i would like to place a module in the body position
    Can you give me a direction how to do this?
    thanks
    willem
    oudemans Friend
    #331030
    fixed it by placing it in an other position.
    willem
    lucine Friend
    #331041
    Ok, you have founded an alternative to the problem,
    but it change nothing to the fact that the “body” position is missing,
    and should absolutely be integrated in the template !
    So I hope that Joomlart team will give me an answer and a solution to this problem …
    Nice day
    lucine Friend
    #331336
    Nobody ???
    Anonymous Moderator
    #331400
    Hi lucine
    In this template, the body position is not exist. With our image, it is the place where is including the content component.
    Hope you understand my explain.
    lucine Friend
    #331407
    I am sorry but I really don’t understand why it’s not possible to have modules & custom html on this place !
    Besides I don’t understand what is the difficulty for you …
    This template is perfect, and I have already showned it to my client !
    I just need a way to include my module in the “body” position.
    I hope that you understand my misunderstanding
    Anonymous Moderator
    #331658
    Hi lucine
    In the case, you can create new position in this place.
    Open templatesja_kyanite_iilayoutsdefault.php file, find following code section at the begin of file:
    $positions = array (
    'left1' =>'left',
    'left2' =>'',
    'left-mass-top' =>'',
    'left-mass-bottom' =>'',
    'right1' =>'right',
    'right2' =>'',
    'right-mass-top' =>'',
    'right-mass-bottom' =>'',
    'content-mass-top' =>'',
    'content-mass-bottom' =>'',
    'content-top' =>'',
    'content-bottom' =>'',
    'inset1' =>'',
    'inset2' =>''
    and change to:
    'left1' =>'left',
    'left2' =>'',
    'right1' =>'right',
    'right2' =>'',
    'content-top' =>'body',
    'inset1' =>'',
    'inset2' =>''
    At that time, you have this position like your idea.
    For full information, please kindly read my thread: http://www.joomlart.com/forums/topic/how-to-create-new-position-in-joomla-1-5/
    lucine Friend
    #331677
    Thank you for your answer,
    even if I have find an other way to solve my problem
    (by including my module in my article).
    Thank you so much for your solution,
    for me the problem is solved.
    Best regards
This topic contains 11 replies, has 4 voices, and was last updated by  lucine 14 years, 9 months ago.
