  • benrud Friend
    #133288
    I’m trying to fix my slideshow so it’s displayed on the homepage only. Nothing is working inside the module 5 position.
    I decided to try and place it in the “body” position but the position “body” isn’t an option.
    How do I correct this?
    Thanks,
    Todd
    mj1256 Friend
    #270272
    did you set the menu assignment to home??
    see screenshot
    1. menu-assignment
    benrud Friend
    #270285
    yes. I’ve tried it as “home” and on “all” but neither work.
    The mainmenu I’m using is a new one. I had trouble with the original one so I deleted it.
    I’ve created a new one called “mainmenu” but now I can’t get it into the original mainmenu area “user 5”.
This topic contains 3 replies, has 2 voices, and was last updated by  benrud 16 years, 3 months ago.
