  • abarneto Friend
    #140792
    I’m putting together a Topaz site and I get a this error:
    5023
    In the body, I frontpaged a single article and it is pushed to the right, leaving a big white space on the left.
    Any ideas what’s going on?
    Thanks!
    1. example
    nguyenhuu quang Friend
    #303189
    send your demo site, allow us to help you
    abarneto Friend
    #303233
    jooleimon Friend
    #303256
    <em>@abarneto 126767 wrote:</em><blockquote>I’m putting together a Topaz site and I get a this error:
    5023
    Thanks!</blockquote>
    I’m seeing the same too,in my trial site. The slide show module on top of the frontpage articles is fine, and the ja_news part is ok, but there is no frontpage module/plugin to handle the frontpage so it is all messed up with large empty space on the left and articles bunched up on the right.
    In your intro to the template, it is stated that “As a result, we just use single JA News module 1.3.1 to dispose articles sorted by sections or categories in JA Topaz homepage, default layout alike JA News front-page is no longer in place as it is now handled by overwritten com_content.”
    So where i com_content, and how to we use it instead of a frontpage module (as in Teline II ?)
    jooleimon
    Arvind Chauhan Moderator
    #303281
    Not sure if this is the fix, but you can give it a try:
    Take backup and open your template.css on line 277
    <blockquote>#ja-contentheading
    .article-block {
    float:right;
    width: 40%;
    }</blockquote>
    Change 40 % to 100%
    Please let us know if it helps.
    regards
    arvind
    jooleimon Friend
    #303301
    No. What the change does is to have each news item in one column take up all the space on the main body. It does not have the structure shown on the demo, which is what I want and expect.
    #303348
    open template.css (line 277)
    #ja-contentheading .article-block {
    float:right;
    width:40%;
    replace
    float:right;
    Css Magician Friend
    #303416
    <em>@quang268 127002 wrote:</em><blockquote>open template.css (line 277)
    float:right;
    width:40%;
    replace
    float:right;
    </blockquote>
    Hi all,
    It has problem because hasn’t Leading.
    You login administrator, Menu- Mainmenu- Home, change Leading: 0 to Leading: 1.
    Or I have ideas : in templatesja_topazhtmlcom_contentfrontpagedefault.php, line 27, you should change : [PHP]
    <div class=”article-block”>
    [/PHP]
    to [PHP]
    <div class=”article-block” style=”<?php if($rowcount<1) { echo ‘width:100%’; } ?>”>
    [/PHP]
    It is very well when your site have leading or not
    jooleimon Friend
    #303762
    Thank you for the instructions. But Leading was always set to 1 so this was not relevant in this case.
    Modified the code to the above suggestion. The slide module + frontpage disappeared.
    Any ideas ?
    jooleimon
    renegades Friend
    #304754
    Has anyone solved this just yet? I’m having the same problem.
    Thanks.
    bossies Friend
    #308054
    I have a work around that will work if your front page is static information and not like a blog
    create a new menu item of type article and select your article that you would like to be your home page. Call the menu item home. Then make the new menu item “Home” default and then unpublish the original Home-Frontpage
    Hope this helps
    omar_ali Friend
    #308983
    You think you buy a template you’ll get the darn thing that works!
    What’s the REAL solution to this EVIDENT problem?
This topic contains 12 replies, has 8 voices, and was last updated by  omar_ali 15 years, 6 months ago.
