  • zenga Friend
    #146282
    I’ve created my site with JA Cooper template, as you can see here : http://groupepv.congonova.org/index.php
    But, I want to reduce the space between the slideshow and the body.
    I tried but I’m not able to push my body up.
    Some one can tell me how to do this ??
    And also if In can put the JA news module in the place of Body ?
    Thanks a lot,
    Jean
    prakash Friend
    #324664
    According to me the module to the right of slideshow may be creating the problem. I replicated it on my system and reduced the right div from current 318 to around 280 and the gap is not found.
    do check and let me know if it works.
This topic contains 2 replies, has 2 voices, and was last updated by  prakash 15 years ago.
