Viewing 6 posts - 16 through 21 (of 21 total)
  • ericdeumo Friend
    #680597
    Please where will I insert the code?
    Can I have an exemple of css code?
    Tank you.
    ericdeumo Friend
    #746971
    Tank you.
    jooservices Friend
    #680599
    Hi there
    # You’ll need apply to custom.css ( if it does not exists than create it ).
    Check out our document for detail
    http://www.t3-framework.org/documentation/customization.html
    # For css border & background please check css document
    http://www.w3schools.com/css/css_border.asp
    http://www.w3schools.com/css/css_background.asp
    Thank you,
    Viet Vu
    jooservices Friend
    #746973
    Hi there
    Thank you,
    Viet Vu
    ericdeumo Friend
    #680888
    Tank you.
    The problem has been solved.
    ericdeumo Friend
    #747069
    Tank you.
This topic contains 21 replies, has 2 voices, and was last updated by  ericdeumo 9 years, 2 months ago.
