  • jdenio Friend
    #126005
    Hey folks,
    Can anyone PLEASE help me get rid of this crazy breadcrumb box (see link). STRANGE THING is in ONLYL shows up in INTERNET EXPLORER.. not Firefox. I have requested this before but nobody has been able to give a solution. I am about ready to launch the site and I cannot figure it out. It is right under the Spotlight modules. I have tried EVERYTHING. IF THERE IS CODE that I can search for and delete then that would be fine.
    http://www.foresite-group.com/index….48&It emid=57
    It is on all the other other page too.:((
    Thanks. Jason.
    mfcphil Friend
    #240120
    You could be looking for
    div id=”ja-pathway”
    Also it could be the top-bg-narrow.png image, at least thats what you get when the grey area is highlighted if you copy the ja rochea code.
    Personally I think it looks a whole lot better with the breadcrumbs on.
    jdenio Friend
    #240124
    I tried to turn them on and they don’t work. I would surely do that if it was easier. I also deleted the breadcrumb module and created another one and that didn’t work either. Is there a way to reinstall that module alone? Thanks.
    mfcphil Friend
    #240679
    Isee your problem is no more..how did you fix it?
This topic contains 4 replies, has 2 voices, and was last updated by  mfcphil 16 years, 9 months ago.
