  • fbernardello Friend
    #982856
    Dear Support, I’m having a problem with the Breadcrumb module, in particular when I have more than one category level.
    Example #01 Note: With a simple path (just 1 category), the breadcrumb is correct: URL: http://www.epadova.com/shopping-padova/negozi-di-scarpe.htm Breadcrumb: YOU’RE HERE > HOME (renamed PADOVA) > LO SHOPPING
    Example #02 Note: With 2 category levels, the breadcrumb is wrong. The first category level is missing: URL: http://www.epadova.com/visitare-padova/chiese/basilica-del-santo.htm Breadcrumb: YOU’RE HERE > HOME (renamed PADOVA) > CHIESE It should be: YOU’RE HERE > HOME (renamed PADOVA) > VISITARE PADOVA > CHIESE
    Example #03 Note: It was a test and a stange case: Just one category, but wrong breadcrumb: URL: http://www.epadova.com/visitare-padova/liston.htm Breadcrumb: YOU’RE HERE > HOME (renamed PADOVA) It should be: YOU’RE HERE > HOME (renamed PADOVA) > VISITARE PADOVA >
    Could you please help?
    Regards, Federico
    Ninja Lead Moderator
    #983036
    It’s very hard to suggest the solution for you without seeing the configuration on your site but you need to follow below to check on your site
    • Menu page and categories of Article: If a menu is selecting with more all categories, it will show the name of menu alias and you can see the example on this link with Technology
    • A category is assigning with many menu items, I guess the problem on your site to regard this. Please check that on your site
    fbernardello Friend
    #983096
    Dear @ninja Lead,
    thank you for your reply.
    I’m sorry, I didn’t understand, but you’re right: hard to find a solution without seeing the configuration.
    I added user and password to my original post.
    Thanks in advance,
    Federico
    #983929
    I tried to help you to detect the configuration on your site but your website is very slow accessing at my end. It’s very hard to help out. In this case, you can disable the menu items and detect this
    fbernardello Friend
    #984027
    Dear @ninja Lead,
    really? So slow you are not able to browse the Admin interface?
    I tryed right now, and it seems very fast. Maybe you found a traffic peak on the backbone…
    #984553
    You can follow the steps below to detect the problem on your site.
    • Disable SEO setting: http://prntscr.com/d4o4be
    • Run with the menu item has a problem from front-end.
    • Go to each menus item: http://prntscr.com/d4o38w and check with all modules are loading with this page and try to remove the duplicate assignment your site
    Or you can use joomla seo extension from JED to redefine all the default path of Joomla as your expectation.
This topic contains 5 replies, has 2 voices, and was last updated by  Ninja Lead 8 years, 1 month ago.
