  • markusthiel Friend
    #166137
    I´m having problem with the breadcrumbs..
    If I change template it works..
    If I use the core joomla breadcrumbs module it works..
    But what I need is the mod_k2_tools to work 😛
    The site is on my localhost so I can´t give you access but perhaps you can recreate the bug?
    himangi Friend
    #400972
    I tried using mod_k2_tools with Ja templates and it did work fine. Only thing I had to checnge was the module position, since a same positions may not be available in all the templates.
    Let me know if you have any other questions.
    markusthiel Friend
    #400984
    Can you try to place it in the “breadcrumbs” position? and use the “breadcrumbs” functionality?
    himangi Friend
    #401077
    I used mod_breadcrumbs in ‘breadcrumb’ position, then it works fine. But mod_k2_tools doesnt show up in the breadcrumb position. I am raising this to Ja developers to check to see if it’s a bug.
    markusthiel Friend
    #401093
    Acctually I found the “bug”
    The code “<jdoc:include type=”module” name=”breadcrumbs” />” makes it impossible to use any other module in that posision..
    The fix is to change it into: “<jdoc:include type=”modules” name=”breadcrumbs” />” (note the ending s in “modules”)
This topic contains 5 replies, has 2 voices, and was last updated by  markusthiel 13 years, 4 months ago.
