  • atticatech Friend
    #152294
    Dear sirs!
    I am experiencing a small problem with JA Ores.
    I have a separator item within the main menu, that is parent to other items. If you click on one of its daughter items, then the Breadcrumbs module does not have the arrow > between them!!!
    This occurs only when the menu contains a separator.
    Could you please look into it?
    John Wesley Brett Moderator
    #349012
    Can you provide a URL so we may look at it?
    Thank you.
    John.
    atticatech Friend
    #350080
    unfortunately my test server does not have internet access but it is very easy to reproduce: just create an item of type “separator” in the main menu, and then create another item (for example, an article item) with the separator item as parent. If you navigate to it, the breadcrumbs line will not have the arrow > before and after the separator item!!
This topic contains 3 replies, has 2 voices, and was last updated by  atticatech 14 years, 5 months ago.
