  • sushismb Friend
    #1074527
    I’ve just installed the JA Company template and also installed the ACM module. It was working great until I tried to edit the content of the Call To Action module settings.
    When it’s accessed the second time, the settings all go back to the default. Whatever I do it just goes back to the default settings. Even I edit in the advance or in the box parameter, it’s the same.
    This is reflected on ALL my other ACM modules.
    I’d appreciate if anyone could help me on how to solve this issue.
    Thank you!
    Pankaj Sharma Moderator
    #1074611
    Kindly check you are using the latest version of template and ACM module, there was the issue in the outdated ACM with latest Joomla.
    If you will face this issue again, kindly share a temp. superuser details of the site in Private reply.
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 7 years ago.
