  • hjalte1983 Friend
    #200962
    Hi Guys.
    Working with this template and Mijoshop has been a challenge. I still got a few issues i hope you can help me with.
    1. there might be a bug with the cart.
    When adding a item to the cart it just says 1 in the cart in the top right corner, and some text/code shows below
    see image:
    When pressing the cart and unpressing it shows right. like this:
    2. The Flags:
    My language switcher is showing out of the screen, depending how big your screen is. on a Macbook it show like this:
    And in Internet Explorer the language switcher doesn’t even show.
    I would really like to move the switcher, maybe before the Home. or even down in the green header_oc bar.
    3. Responsive issues.
    How can i fix the search bar?, also as you can see there is a issue with the language switcher and menu.
    Also on an ipad there should be plenty of room for my 3 menues : Home Shopping Cart Checkout, but not showing anything.
    4. margin issue from old thread.
    <em>@hjalte1983 443494 wrote:</em><blockquote>@Ninja Lead i’ve been working back and forth with the margins, and its now set to -150 which look good in top.
    But i’m having trouble at the bottom:
    Also when going responsive it look like this:
    Can you help me out,
    Regards.</blockquote>
    Been stuck with this for weeks., hope you can help me out 🙂
    Launching the site is getting closer
    regards-
    1. cart
    2. correct-cart
    3. Screen-Shot-2014-08-05-at-15.26.24
    4. Phone1
    5. Ipad2
    Ninja Lead Moderator
    #548098
    How can you add left category in Product page?
    I see the left category on your site could not support responsive. When I set back to default theme from Mijoshop theme and it could not work too.
    1. left_category
    hjalte1983 Friend
    #548142
    Just using the default Category module in Mijoshop
    1. column-left
    #548246
    I’m so sorry about this, JA Decor template only supports responsive as in our concept and covers all popular layouts, it may not be possible to provide responsive layouts for all options. I tried to find from Mijoshop forum but I could not see the info about default Mijoshop theme supporting responsive layouts, you can raise this problem to Mijoshop forum here hope you will get best answer there.
    hjalte1983 Friend
    #548282
    @ninja Lead Okay, what about issue 1 and 2?
    #548411
    <em>@hjalte1983 444234 wrote:</em><blockquote>@Ninja Lead Okay, what about issue 1 and 2?</blockquote>
    #1: This is a problem of our product, I have raised this bug for development team to fix here
    #2: This is a customize languageswitcherload position in your layout but you can try to fix it with my solution below
    Open templates/ja_decor/css/custom.css file
    find and change
    .dropdown-menu {
    min-width: 50px;
    div.mod-languages ul {
    margin: 0;
    padding: 0;
    list-style: none;
    display: -webkit-inline-box;
    top: 10px;
    to
    .dropdown-menu {
    min-width: 60px;
    margin: 0;
    padding: 0;
    list-style: none;
    display: inline-flex;
    top: 10px;
    .t3-header .main-container .pull-right {
    margin-right: 60px;
    hjalte1983 Friend
    #548460
    Thanks,
    about nr. 4
    Is this something you can help me with ?
    hjalte1983 Friend
    #548681
    Hi @ninja Lead
    The language switcher won’t show on ipad and macbook “13
    1. Screen-Shot-2014-09-08-at-09.49.42
    #548692
    The problem of language switcher on ipad and mackbook “13, I just fixed it with the solution below :
    Change
    margin: 0;
    padding: 0;
    list-style: none;
    top: 10px;
    To
    margin: 0;
    padding: 0;
    list-style: none;
    top: 10px;
    and #4 of your problem, you can try to use the solution below
    find and change
    .ja-product-grid {
    margin-bottom: -150px;
    To
    .box_oc .featuredproducts > .ja-product-grid {
    Let me know if it helps
    hjalte1983 Friend
    #548710
    Thanks A LOT ! 🙂
    hjalte1983 Friend
    #550373
    hey @ninja Lead , any update on the bug?
    http://pm.joomlart.com/browse/JADECOR-216
    #553564
    <em>@hjalte1983 446837 wrote:</em><blockquote>hey @ninja Lead , any update on the bug?
    http://pm.joomlart.com/browse/JADECOR-216</blockquote>
    Apologies for this late response, somehow I missed this thread.
    You can try to use temporary fix with this bug
    Open templates/ja_decor/css/custom.css file and add the css style below
    #header_oc #cart .heading a {
    overflow: hidden;
This topic contains 12 replies, has 2 voices, and was last updated by  Ninja Lead 10 years, 1 month ago.
