So to summarize all problems I am facing so that you guys can take a look at it 🙂
1) publish button is a problem (with cashing I guess…) – I have to use incognito mode all the time otherwise its not working
2) as in this https://www.joomlart.com/forums/topic/cant-add-more-slides/ theres still an issue with slider in category blog
3) when I akeeba backup subdomain and move site to a new one it looses custom css but more important – content created BEFORE akeeba backup resets itself whenever you try to edit it as you can see here:
https://www.joomlart.com/forums/topic/pre-akeeba-content-resets-when-i-try-to-edit/
Thank you Saguaros for your hard work and looking forward to the next and better releases!
Have a good day.
