May 8, 2012 at 3:03 pm #176841
Hi I have the portfolio installed, but on my article listing in the left module position there seem to be an error:
http://newcmr.com/frn/jupgrade/index.php/news-a-events
So on the left after each bullet points there is a brake. Is it possible to remove as it is driving me crazy to find where it is set up.
In the display options of the module I can set up the header typer (h1, h2 or h3 etc) but all of them put there a brake.
It is an Articles Category module there.
Please help me on this!
chavan Friendchavan
- October 2014
- 1440 times in 1290 posts
May 10, 2012 at 4:31 am #452326May 15, 2012 at 10:25 am #453119Thanks for your reply.
I know, but my problem is that I do not find the css to edit.
I see it is not a css file it is generated somehow by php???Any idea where to edit it?
<em>@Do Ha 318796 wrote:</em><blockquote>Hi
You should find and remove margin line in template.css as the attached image.
</blockquote>
May 15, 2012 at 11:04 am #453122Finally I found it!!!!! 😀 :p
plugins/system/jat3/jat3/base-themes/default/css/template.css
It was the css compression that hid it from me…
Thanks for your reply anyway
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by peterendersz 12 years, 6 months ago.
Bulletpoint problems in modul
