  • jonasso Friend
    #175005
    Greetings,
    The issue I’m having seem to be related to caching. When Template caching is enabled some links do not point to the correct location and and images do not load.
    For example the article images images and the images in the Custom HTML module do not load and the link o the logo points to an incorrect location (404 Error);
    http://vidademulher.com.br/canais/maes-a-filhos/gravidez/144-pilulas-contraceptivas-e-falhas.html
    What can we do in order to get this working.
    I’m using Joomla 1.7
    Best regards,
    I’m sorry but with the account provided i cannot do anything on your site please update the rights for that user to administrator
    and also check the links for your images if you have changed seo settings the links must be rewritten
    jonasso Friend
    #443776
    Dear Pavit,
    I’ve updated the user to administrator.
    The only SEO settings I’ve changed was the core Joomla SEO settings (when I first created the site, back in Joomla 1.6 days), which I believe I should be allowed to change. Shouldn’t I?
    Thanks for your help,
    I need a super user account, i cannot check your global configuration from the backend, if you try to clean your cache the images are showed correctly on your arrticles, so i think the problem is there, but needs to be better checked
    jonasso Friend
    #443781
    Dear Pavit,
    You are now a Super User;
    The images are displayed correctly in some articles, specially on the Featured Articles view;
    It also do not work correctly in other components like:
    http://vidademulher.com.br/canais/maes-a-filhos/calendario-da-mulher.html
    http://vidademulher.com.br/canais/maes-a-filhos/gravidez-semana-a-semana.html
    Best regards,
    Please check now
    if is as you expected to be ?
    jonasso Friend
    #443784
    Dear Pavit,
    I see you’ve changed the image path of the image including the entire path, including domain, however this is not the right way to do it;,
    As I mentioned earlier, the problem also lies in the links, not only article images, but also the Custom HTML module images;
    Go to http://vidademulher.com.br/canais/maes-a-filhos/gravidez/144-pilulas-contraceptivas-e-falhas.html and click on the site’s logo and you will see what I’m talking about.
    Best regards,
    <blockquote>I see you’ve changed the image path of the image including the entire path, including domain, however this is not the right way to do it;, </blockquote>
    I have changed anything i have only disabled your editor
    jonasso Friend
    #443787
    Dear Pavit,
    That’s odd… disabling the editor should not change the link on the image.. I’ll check
    What about the links? The link on the logo is not pointing to the site’s main page.
    PS: The strangest behavior is if i disable the Page Cache (Joomla core) plugin it works.
    Any idea?
    Best regards,
    jonasso Friend
    #443789
    Dear Pavit,
    Are you still working on this?
    May I enable the editor?
    Best regards,
    jonasso Friend
    #443798
    Solved!
    It worked right after I moved the Joomla core Cache plugin to the second last position, right before the JAT3 System plugin.
    All the best,
This topic contains 11 replies, has 2 voices, and was last updated by  jonasso 12 years, 9 months ago.
