July 21, 2014 at 1:30 pm #199854
I think this is not template issue but maybe i get some help.
I installed eventbooking calendar and when first i loading page i have this :Once i refreshing the page everything is working (i tested chrome, ffox and ie same issue)
Later i installed another calendar component and still have this issue on second component too.
is it a PHP setting problem or css?
thank you-
Adam M Moderator
Adam M
- May 2014
- 1271 times in 1235 posts
July 22, 2014 at 4:52 am #543067Hi,
Could you please provide your site url so I can have a look at the problem ?
July 22, 2014 at 7:13 am #543086http://david.deb.hu
if i load :
http://david.deb.hu/index.php/programok look like working.
but if i start from home and i select programok menu then dont work only when i refresh
thank youAdam M ModeratorAdam M
- May 2014
July 22, 2014 at 9:02 am #543101Hi,
Please navigate to Admin >>> Extensions >>> Template Manager >>> choose your current template >>> switch to tab General >>> temporary disable CSS compression and recheck.
1 user says Thank You to Adam M for this useful post
July 23, 2014 at 5:24 am #543182after changes same issue have.
check pm please
- May 2014
July 23, 2014 at 10:30 am #543213Hi,
Please navigate to Admin >>> Menus >>> Main Menu >>> Programok >>> switch to tab Page Display >>> type noajax in option Page Class and recheck.
July 23, 2014 at 7:36 pm #543266working 🙂
you are a real support hero
thank you -
Viewing 7 posts - 1 through 7 (of 7 total)This topic contains 7 replies, has 2 voices, and was last updated by hajdukultura 10 years, 4 months ago.
