January 17, 2013 at 1:09 pm #184095
Hello all!
Hope you could help me with the following problems.
First question:
On my frontpage of my website http://www.tasmanvakantie.nl I want the “content column” not to be 3 grids width but 2 grids with. When i take a look at templatecsslayout.css it looks like it should be this way already. Changing the parameter of .ja-frontpage #ja-content won’t give any effect to my frontpage. When changing #ja-content is does change. But I want two grids for my content and for the rest of my webpage 3 grids, as it should be with the information below. Could anyone tell me what I do wrong and how I can fix this?
/* Main Content */
#ja-content {
width: 720px; /* 3 grids */
}.ja-frontpage #ja-content {
width: 480px; /* Frontpage Content 2 grids */
}Second question:
Can someone tell me what’s the easiest way to use K2 instead of the content part on the page. I’ve tried to use K2 as a module in position5 or position7 but it didn’t really worked out. So I really want to know what is the easiest way to place K2 in the content position, and if this should be as module or how I refer this to the content position.
I am using Elastic template. Do really hope you guys can help me out with this!
Best regards,
Lennart van Oirschot
January 17, 2013 at 2:14 pm #480201January 17, 2013 at 3:35 pm #480209I’ve also tried to edit layout-wide.css wich is viewed in on my computer but without any effect. Could someone please help me out?
Saguaros ModeratorSaguaros
January 18, 2013 at 8:22 am #480293Hi lenvo,
This wiki guide will help you more about this template’s layout: http://wiki.joomlart.com/wiki/JA_Elastica/Grid_and_Layout
<blockquote>I’ve tried to use K2 as a module in position5 or position7 but it didn’t really worked out.</blockquote>
>> You can check the layout file you are using whether these 2 positions are defined or not<blockquote>I’ve also tried to edit layout-wide.css wich is viewed in on my computer but without any effect.</blockquote>
>> Please make sure that after making change, you clean all caches.AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 2 voices, and was last updated by Saguaros 11 years, 10 months ago.
Can anyone help me with my content grids width problem on frontpage?
