  • gatsbycat Friend
    #178898
    I am using purity II on Joomla 2.5.6. Adding ?tp=1 to the end of the URL does not display the module positions, it just displays “” over all of the positions. Is there some configuration change or fix that must be applied in order to view the module positions on my site? This worked at some time in the past before upgrading to recent versions of Joomla. Also it works if I change the default template to one of the templates included with Joomla, such as Beez; it just doesn’t work with purity II. Any suggestions welcome, thanks!
    Hi there,
    Did you have this template and extensions uptodate? Please update the latest version.
    mraza82 Friend
    #460818
    <em>@gatsbycat 329053 wrote:</em><blockquote>I am using purity II on Joomla 2.5.6. Adding ?tp=1 to the end of the URL does not display the module positions, it just displays “” over all of the positions. Is there some configuration change or fix that must be applied in order to view the module positions on my site? This worked at some time in the past before upgrading to recent versions of Joomla. Also it works if I change the default template to one of the templates included with Joomla, such as Beez; it just doesn’t work with purity II. Any suggestions welcome, thanks!</blockquote>
    Go to Extensions > Template Manager > on the top right buttons panel, click on OPTIONS:
    Then click to enable the module positions.
    This could be the only reason of the problem which I also had a month ago.
This topic contains 3 replies, has 3 voices, and was last updated by  mraza82 12 years, 4 months ago.
