test melih
 melih
  • midhat Friend
    #207199
    I use JaObelisk template on my site. I use ReCaptcaha and all properly configured. When you try to register using modules Ja Login all works.
    But if you mess up the registration, module redirects you to the registration page and there is a problem. ReCaptcha does not appear and it is impossible to complete the registration.
    I try to open registration page http://planinarenje.ba/registracija, but ReCaptcha missing. On this page ReCaptcha missing in ja Login module too. On all other pages Ja Login works properly.
    How can I solve it?
    Thanks,
    Midhat
    Ninja Lead Moderator
    #573697
    You can pm me super admin login backend of your site, I will help you to check it further.
    #738711
    midhat Friend
    #574616
    Thanks,
    I sent you a PM
    #574714
    <em>@midhat 478881 wrote:</em><blockquote>Thanks,
    I sent you a PM</blockquote>
    I could not access backend of your site and it’s auto direct to homepage when I tried to access backend of your site. Please check and pm me the URL to access backend site.
    #641058
    #739722
    midhat Friend
    #574808
    Sorry,
    I sent PM again
    #574979
    <em>@midhat 479135 wrote:</em><blockquote>Sorry,
    I sent PM again</blockquote>
    Look at the screenshot here
    You will see the problem captcha plugin on your site at registration page. I checked other pages but I could not see the problem as in registration page.
    You can try to revert to default Joomla template to see if its a issue of your site or our template. You can submit the request to them here hope you will get best answer from there
    1. Screen-Shot-2015-06-22-at-12.13.32
    midhat Friend
    #575254
    Tryed with Protostar, but is same. I sent a request to the
    https://github.com/google/recaptcha/issues/56
    midhat Friend
    #575714
    The problem was in K2 component, which I do not use, but was associated with the registration page. In K2 captcha was not enabled.
    Solution:
    1. Enable captcha in K2
    2. Uninstall K2
    midhat Friend
    #642043
    Solution:
    2. Uninstall K2
    midhat Friend
    #740703
    Solution:
    2. Uninstall K2
This topic contains 13 replies, has 2 voices, and was last updated by  midhat 9 years, 7 months ago.
