beastmode54 JA JobBoard
beastmode54
- November 2007
- 20 times in 1 posts
October 5, 2009 at 12:07 pm #144901Hey guys here is a Citrus Carpet Cleaning site using ja_nickel and ja tabs. IThe companys name is Citrusolutions. Let me know what you think.
mfcphil Friendmfcphil
- 388 times in 133 posts
October 5, 2009 at 2:16 pm #319581LOVE IT!!
Think you logo works really well in the bottom against the grey background, the text in your JOIN THE TEAM module needs a little attention to make it look correct.
Keep up the good work! 😉
beastmode54 JA JobBoardbeastmode54
- November 2007
October 5, 2009 at 3:45 pm #319588Thanks for the input….yea i think i need to change the the hyper link color also.
nefar Friendnefar
- December 2007
- 42 times in 1 posts
October 5, 2009 at 6:48 pm #319601Took a little long to load the main page and the about company section. Might want to turn on cache if you haven’t. The about company first picture with “the broone family” I would think about putting “the broone family” title under the picture and centered to match the rest of the photos.
“Process section” the text next to the picture under “is your house making you sick” is not wrapping correctly it appears like so :
If you suffer from allergies, colds and flu-like symptoms more often than seems
normal,
try this simple test. The next time you leave your home for a few days, keep a
diary
describing how you feel. Monitor your physical condition for several days before,
duringSame page top graphic I would make the larger orange text even with the picture and then start the numbered list. Way it shows now first sentence is over the picture and the numbered list is indented.
Testimonial section has some type of gray vertical line going through the text sets off the eye.
Main page :
Join the team block text is to close to end of block.
Why citrus? Block has black text everything else is green.
Other then some slight tweaking everything looks good.
- November 2007
October 5, 2009 at 7:01 pm #319603Thanks for the input…somethings i guess i over looked.
didima Frienddidima
- 31 times in 3 posts
October 18, 2009 at 11:54 pm #320899nice site very colourfull, just need seo freindly links thats all, perfect
- November 2007
October 19, 2009 at 1:31 am #320906Thanks, yea i am working with their marketing person on the SEO. Thats one thing im just now starting to learn. Thanks for the info.
This topic contains 7 replies, has 4 voices, and was last updated by beastmode54 15 years, 2 months ago.
