  • haguet86 Friend
    #161784
    Hey. I keep running into a problem when it comes to setting images in k2. I am trying to set a category image under k2 >> categories >> category 1 >> then i go to the image tab browse for my image (with the correct size) and hit apply.
    It says the changes were made but the same placeholder image appears where my new image should of. Or another occurrence after I upload is that the image appears but it is alot smaller than the original file.
    Same thing is happening for articles as well. Any and all help is appreciated. Thank you! 😀
    jersonjunior Friend
    #382765
    You are using joomla quickstart or original?
    haguet86 Friend
    #382798
    Quickstart. Thank
    #382849
    <em>@haguet86 229478 wrote:</em><blockquote>Hey. I keep running into a problem when it comes to setting images in k2. I am trying to set a category image under k2 >> categories >> category 1 >> then i go to the image tab browse for my image (with the correct size) and hit apply.
    Same thing is happening for articles as well. Any and all help is appreciated. Thank you! :D</blockquote>
    Dear haguet86,
    I login to your K2 back-end,tried to set image for a k2 category and I did not see the problem,Please make sure you select to replace the old image by the new if the category already has an old image.
This topic contains 4 replies, has 3 voices, and was last updated by  Sherlock 13 years, 8 months ago.
