  • robchocolate Friend
    #144720
    For one page I am using the category blog layout with zero leading articles and two columns. I have ordered the articles by date created. However, I would like the multi-column order (set in the advanced parameters) to be down. However, no matter how I set the multi-column order (down or across) it looks the same – the articles are always ordered across. I noticed in other forums discussing other templates this tends to be a general problem: unless using JA Purity or Rhuk_Milkyway, the multi-column order setting does not work. Do you have a solution?
    Many thanks in advance.
    John Wesley Brett Moderator
    #342405
    Is this still an issue?
    Or have you resolved it?
    Thanks,
    John.
    robchocolate Friend
    #342496
    Nope, no fix.
    Dear John!
    Please help me anwer this issue
    jamjodesign Friend
    #401425
    Any solution to this issue? I have the same problem but my order is down when I want it to be across. No matter what I do the order is always down the column. Changing Multi Column Order makes no difference.
    #401753
    <em>@jamjodesign 253494 wrote:</em><blockquote>Any solution to this issue? I have the same problem but my order is down when I want it to be across. No matter what I do the order is always down the column. Changing Multi Column Order makes no difference.</blockquote>
    hi jamjodesign,
    Did you see this problem in the category blog layout and the template is telineiii v1 ?
    flying_scot Friend
    #423135
    <em>@Dat Hoang 253944 wrote:</em><blockquote>hi jamjodesign,
    Did you see this problem in the category blog layout and the template is telineiii v1 ?</blockquote>
    I am having the same problem in JA_Anion on Joomla 1.7.2. No matter what I do with the blog layout settings the articles will not display in 3 columns across…only down. :((
    bennie01 Friend
    #463485
    Same problem here, using Joomlart Minisite 2.5 :((
    #463528
    <em>@bennie01 333425 wrote:</em><blockquote>Same problem here, using Joomlart Minisite 2.5 :((</blockquote>
    Hi bennie01,
    You could open the file of templatesja_minisitecsslayout.css look for this css
    .cols-2 .item { width: 50%; }
    .cols-3 .item { width: 33.33%; }
    .cols-4 .item { width: 25%; }
    .cols-5 .item { width: 20%; }
    and change it to
    .cols-2 .item { width: 50%;float:left }
    .cols-3 .item { width: 33.33%;float:left }
    .cols-4 .item { width: 25%;float:left }
    .cols-5 .item { width: 20%;float:left }
    I hope it would help !
    #463530
    <em>@flying_scot 280711 wrote:</em><blockquote>I am having the same problem in JA_Anion on Joomla 1.7.2. No matter what I do with the blog layout settings the articles will not display in 3 columns across…only down. :((</blockquote>
    Hi flying_cot,
    I think It’s better if you upgrade your site to Joomla 2.5, Joomla 1.7 no longer been supported and it might contains potential bugs 🙁
    bennie01 Friend
    #463653
    Worked! Thanks a ton Sherlock! 🙂
This topic contains 11 replies, has 7 voices, and was last updated by  bennie01 12 years, 5 months ago.
