  • snjofac Friend
    #139266
    I install Catpopup module on Zeolite template and its working ok, but problem is with pop window. He is behind top part of page. Top part of page, including menu is not cover with gray.
    Here is image
    Please help.
    wooohanetworks Friend
    #296735
    The z-index controls what elements is shown above others. So the header and the parts not covered by the pop up are behind it because the z-index for those is higher. Now, with the header not being stuck behind grey, I personally would not mind, it keeps users still “on the site” and not “like in a dark room somewhere else”
    I have some problem with my computer right now and can’t open files properly, so I can’t take a look if the module has an own css, what it should have. So basically you have to find a css inside the directory and in this css somewhere you should find “z-index” and a number following it in a row that must be called somehow like “#catpopup pop up”. You can set this to 10000 for example, this should be high enough to set the grey covering above all. When the header is still above it, try setting it even higher than 10000.
    When all this does not work out, maybe someone else can help.
    snjofac Friend
    #296744
    Many thanks! It’s working now.
    #296745
    Good, whenever you may install a new module and some parts are not covered again, you know where to look, either you lower the z-index in the new modules css or higher the one of this pop up again, rather you higher this one again to avoid that suddenly the new module etc. is having problems with other parts, in case you set it too low then, you never know…;)
This topic contains 4 replies, has 2 voices, and was last updated by  wooohanetworks 15 years, 9 months ago.
