  • bob66622 Friend
    #159612
    When I change the backgroud color, unfortunately the corner of the module show rectangular because the rounded corner color of the module are white,
    it is possible to edit the color of the corner, and the background color too?
    thanks again
    best regards
    aman204 Friend
    #374764
    You will need to edit these images in relative images folder of specific template::
    ../images/box-br.gif
    ../images/box-bl.gif
    ../images/box-tr.gif
    ../images/box-tl.gif
    and then, re-upload the updated images with same name respectively
This topic contains 2 replies, has 2 voices, and was last updated by  aman204 13 years, 10 months ago.
