  • Elinam21 Friend
    #939527
    How can I change the background color without affecting the main body of the template.
    Please see the attached image
    1. backround
    Pankaj Sharma Moderator
    #939603
    Find the suggestion given in this thread for the same matter .
    Beside you can apply different bg color on different div classes using custom.css file .
    You can check the div class name via browser inspect element tool .
    Hope it helps .
This topic contains 1 reply, has 2 voices, and was last updated by  Pankaj Sharma 8 years, 7 months ago.
