  • Daniel Löf Friend
    #138385
    How can I change the light grey body background color?
    anisjolly Friend
    #292640
    You need to change the followinf code in the template.css file:
    #ja-containerwrap, #ja-containerwrap-c, #ja-containerwrap-cm, #ja-containerwrap-f, #ja-containerwrap-m {
    background:#EEEEEE none repeat scroll 0 0;
    border-top:1px solid #FFFFFF;
    clear:both;
    change the #EEEEEE value to whatever the hex value is for the colour you wish to chnage it to.
    Hope that helps
    Daniel Löf Friend
    #292651
    Thanks, found it!
    anisjolly Friend
    #292653
    glad the fix worked 🙂
    Caleb Tseu Friend
    #294512
    Problem solved!;)
This topic contains 5 replies, has 3 voices, and was last updated by  Caleb Tseu 15 years, 9 months ago.
