  • schase Friend
    #126510
    This template uses a gif image for the background, but I want to use a jpg instead. I understand the reason for the gif (the transparency at the top) but that is not a problem for me. Is there any way I can force the template to look for body-bg.jpg rather than body-bg.gif? I tried editing the template.css file, but it still looks for a gif instead of a jpg.
    instantinlaw Friend
    #241950
    If using the J1.5 template, you will probably need to change the image name in the templateDetails.xml as well.
    And if that does not work, you can have a look at the template index.php, sometimes it’s part of the template.
    Good luck.
    bigrk Friend
    #242049
    It should also be referenced in the CSS of the template. You will need to change the gif to jpg in there.
This topic contains 3 replies, has 3 voices, and was last updated by  bigrk 16 years, 10 months ago.
