  • sergkon Friend
    #184515
    HI ALL !
    Anybody can help me?
    How can i change in different module
    Title Font and background color for title in module?
    Thank you
    Phill Moderator
    #481714
    That all depends on what you want to change exactly. If you post exact details then we can give you the css code changes you need to make. We will need a link to your site and full details of what you want changed.
    Alternatively and the best way (as it will be quicker and you can experiment) is to use the excellent Firebug tool for Firefox. With this you can simple click on any element and you can see the exact css that controls it. You can even make live edits to see what it looks like before committing changes. In the case of JA template you will need to se css optimization to “No” in the template manager first or you would see the compressed css instead of the actual css files.
    sergkon Friend
    #481725
    i need change background color and font in title in some custom module in different position !!!
    can you help ?
    Phill Moderator
    #481743
    Of course we can help.
    <em>@phill luckhurst 357743 wrote:</em><blockquote>That all depends on what you want to change exactly. If you post exact details then we can give you the css code changes you need to make. We will need a link to your site and full details of what you want changed
    .</blockquote>
    The best way to do this is with a custom module class but we need all the details to help you.
This topic contains 4 replies, has 2 voices, and was last updated by  Phill 11 years, 11 months ago.
