January 26, 2018 at 8:27 am #1088617Hi Rob,
Kindly share the FTP account also, I will check for you.
pagefactory Friendpagefactory
- March 2012
- 3 times in 1 posts
January 29, 2018 at 8:55 pm #1089012This reply has been marked as private.Saguaros ModeratorSaguaros
January 30, 2018 at 9:17 am #1089117Hi,
I just checked your site and saw that the page: http://www.oostveen.nu/index.php/in-de-regio doesn’t use sidebars (left/right) so it loads this layout: /templates/ja_edenite_ii/tpls/blocks/mainbody/no-sidebar.php
While this layout doesn’t include the content-mass-top & content-mass-bottom block so that you didn’t see module on this page. I just updated this layout and you can see that modules are showing now.
<div id="t3-mainbody" class="container t3-mainbody"> <div class="row"> <!-- MAIN CONTENT --> <div id="t3-content" class="t3-content col-xs-12"> <?php if ($this->countModules('content-mass-top')) : ?> <!-- CONTENT MASS TOP --> <div class="t3-content-mass-top <?php $this->_c('content-mass-top') ?>"> <jdoc:include type="modules" name="<?php $this->_p('content-mass-top') ?>" /> </div> <!-- //CONTENT MASS TOP --> <?php endif ?> <?php if($this->hasMessage()) : ?> <jdoc:include type="message" /> <?php endif ?> <jdoc:include type="component" /> <?php if ($this->countModules('content-mass-bottom')) : ?> <!-- CONTENT MASS BOTTOM --> <div class="t3-content-mass-bottom <?php $this->_c('content-mass-bottom') ?>"> <jdoc:include type="modules" name="<?php $this->_p('content-mass-bottom') ?>" /> </div> <!-- //CONTENT MASS BOTTOM --> <?php endif ?> </div> <!-- //MAIN CONTENT --> </div> </div>
Kindly check.
- March 2012
January 30, 2018 at 4:07 pm #1089178This reply has been marked as private.Saguaros ModeratorSaguaros
January 31, 2018 at 3:57 am #1089281Yes, Rob!
I applied the same change as above into the file: /tpls/blocks/mainbody/one-sidebar-right.php
and it’s showing now.
Cheers!
- March 2012
January 31, 2018 at 5:41 pm #1089440This reply has been marked as private. -
This topic contains 6 replies, has 2 voices, and was last updated by pagefactory 6 years, 10 months ago.
The topic ‘change Edenite into Edenite ii , menu and module problems’ is closed to new replies.
