gringo211985 Friend
gringo211985
- May 2012
- 123 times in 27 posts
May 29, 2014 at 11:18 am #198276Hi there,
I’m trying to change the default amount of products per row to 3, I have managed to change the % width to make the 3 appear but I am having a problem see screenshot
As you can see there is a missing column / product after product number 5.
How do I fix this so I don’t have any gaps in the product lists? I had a Google round but the only thing I could find is a mention to tpl files π
Thanks in advance to anyone that can help me with this π
May 30, 2014 at 3:47 am #537158It’s displaying fine now: http://prntscr.com/3nwu1p. Did you get it solved yourself?
gringo211985 Friend
gringo211985
- May 2012
June 12, 2014 at 2:01 pm #538731Hi Saguaros,
I did manage to fix this myself, if anyone is interested it’s in the components/com_mijoshop/opencart/catalog/view/theme/bookshop/template/product/category.tpl file where on around line 69 it says,
$number_in_row = $tplparams->get(‘number_in_row’,5);
$number_in_row_table = $tplparams->get(‘number_in_row’,5);
$number_in_row = $tplparams->get(‘number_in_row’,5);Change the 5 to whatever amount of products you want per row, hope this helps anyone looking for a solution π
1 user says Thank You to gringo211985 for this useful post
June 13, 2014 at 2:47 am #538777Thanks for sharing solutions π
Saguaros 10 years, 7 months ago.
Change sort order to 3 products per row
