  • pootch Friend
    #1087805
    Hello.
    Can anyone tell me how to change the width of the left side body.
    I think normally there is the left sidebar, but i dont use it.
    I want it to be a fixed size.
    Thanks for help.
    Pootch
    1. Unbenannt
    pootch Friend
    #1087807
    Should be like that (see attch) – fixed size.
    1. Unbenannt-1
    Pankaj Sharma Moderator
    #1087936
    If you want to change the template width here is documentation helps you. To change the width of the sidebar, you have to change the column size from template layout php files.
    In /tpls/blocks/main body/ open the layout files you are using in template layout section.
This topic contains 2 replies, has 2 voices, and was last updated by  Pankaj Sharma 6 years, 10 months ago.
