  • kadad Friend
    #158650
    I would like to know if it is possible to change color of the template in general. For example, I have a color in my logo and want the blue color to be exactly the same. Can I change it?
    The second part of my question is concerning contextual changes. I have three major parts in my website, which have three color identities.
    First I would like the mega menu that will display those parts to change color considering which color identity / site part it reffers to.
    Beside, I would like, if visitor clicks on red site menu link, to display red template through the page, and the same if he changes to another part of the site.
    I won’t be offended if you tell me I’m not clear…
    Thank you.
    Phan Gam Friend
    #371618
    For your request, i think you need change css style for site color. It is possible.
    kadad Friend
    #371699
    Thanx for your answer, but how do I do that, and wich of my question do you answer.
    Thank again
    Phan Gam Friend
    #371830
    i think you should clone JA Raite template into 3 templates, ex JA Raite Green, JA Raite Yellow. (After cloning, you need to goto cloned folder, open templateDetails.xml file and change name params
    [<name>JA_Raite_Green</name>].
    And then, you can open clone template in backend, set Default Style to color you wish and assign menu items for that template.
    With this way, One menu item will have colored style.
    Other way, you dont need clone template, for each menu items, you have to switch it to External Link, and append params ja_color=COLOR NAME to menu Link.
    Hope that helps
This topic contains 4 replies, has 2 voices, and was last updated by  Phan Gam 13 years, 11 months ago.
