June 7, 2011 at 10:53 am #164926
I would like to change the color of left side column and change the font color on left side too, I have looked quite a bit but can’t achieve what I want.
http://www.villagevoicebookshop.com
I wold be very grateful for any help.Thanks
Yann
pritam Friendpritam
- April 2011
- 125 times in 113 posts
June 7, 2011 at 12:37 pm #395094Hello,
Can you please clarify with screenshot that where you want to make changes , So that I can help you better.
June 7, 2011 at 1:32 pm #395110Thank you for your quick reply, please attached sreen shot, what i mean is the area highlighted, from top to bottom of the left column and then chage the color of the texts underneath so that they can be readable.
Thanks a lotYann
June 8, 2011 at 5:46 am #395181Hi
In your layout.css(line no.74) following changes are required :
#ja-left .ja-l1 .ja-col
background :#FF99FF none repeat scroll 0 0;
color:#FFFFFF;
width:100%;
}I hope this will helpful for you.
AuthorPostsViewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by amita 13 years, 7 months ago.
changing color of left side column and changing font color on left side too
