December 1, 2011 at 5:06 pm #171347
Dear All,
I’ve this strange problem. Everything is fine with the homepage layout of the template, but as soon as I expand an article (clicking on “read more”, for example) or open an internal link, the entire structure changes and it seems that the css are lost.
Here the images of the homepage and of a different page after I’ve opened any kind of article.I’ve reinstalled, updated (1.73) and checked the css but everything seems ok.
What could be?thanks a lot
Matteo
kobenes Friend
kobenes
- April 2010
- 29 times in 28 posts
December 1, 2011 at 6:36 pm #427504If you set to Yes your SEF settings from Global Configuration, could you set them No and check if your problem is fixed?
December 2, 2011 at 12:38 am #427517yes, problem fixed! Thanks a lot!!! So no way to use the SEF
December 5, 2011 at 8:46 pm #428082Hello,
I’m using JA Rave, and I said “No” to SEF Global setting. After publishing the HTML rich article featured, I then get the whole template squished 😮 into the middle column after setting the article to “Featured” for the home page. I did use the read more option and “Sample-data articles” category.
Here’s my due diligence:
I tried a text only article with no “read more” option. No problems. Then, I added the “read more” to the same text again in another post. Goo – still no problems. So, could it be something about the HTML I’m copying and pasting into the form when I submit an article as a user/author? Is it taking over or breaking the CSS hold on the template?So, I can’t move forward with normal HTML blog-like, “read more” postings yet – please advise – thanks!
Viewing 4 posts - 1 through 4 (of 4 total)This topic contains 4 replies, has 3 voices, and was last updated by techvenue 12 years, 11 months ago.
