  • borglindata Friend
    #119960
    I have tryid to change the color of JA Shopping II theme in the index file.
    I try to change it from default to blue, but it will not change.
    <blockquote>
    # BEGIN: TEMPLATE CONFIGURATIONS ##########
    #support extra color themes
    $ja_color_themes = array(‘default’, ‘blue’, ‘green’); // You can add more color array if needed
    # Change the width of the template
    $ja_width_default = ‘wide’; // ‘narrow’: 800×600; ‘wide’: 1024×768; ‘auto’: fluid width
    # default color
    $ja_color_default = ‘blue’; //blank for default, else pick one of in extra color themes $ja_color_themes
    #font size default
    $ja_font_size_default = 3;
    # Enable users option
    $ja_tool = 0; // 0: disable all; 1: disable color, enable font; 2: enable color, disable font; 3: enable all.
    # Choose your prefer Menu Type
    $ja_menutype = 1; // 1: Split Menu; 2: Son of Suckerfish Dropdown Menu; 3: Transmenu; 4: Script Dropline Menu;
    # END: TEMPLATE CONFIGURATIONS ##########
    </blockquote>
    Please can someone help me out here.
    Thanks for all answers
    instantinlaw Friend
    #219060
    Hi it looks right to me. Try clearing your browser cache. Maybe the cookie is set for the default color.
    If that doesn’t work, copy and paste this over what you have done
    <blockquote>$ja_color_default = ‘blue’; //blank for default, else pick one of in extra color themes $ja_color_themes</blockquote>
    Good luck.
    borglindata Friend
    #219064
    Thanks for answer, I found a solution.
    I first open up the Site Tool so I can choose the blue color.
    The blue color is set, and I then deactivete the menu Site Tool again.
    So now it worck great. You can wive my site here http://borglindata.no
    Thanks for help 🙂
    Roy 🙂
This topic contains 3 replies, has 2 voices, and was last updated by  borglindata 17 years, 8 months ago.
